Sig 4*60.... Maybe??
Barland,
It is a really quick build. Once you get one wing done you can build the second in no time flat. I think that if I really wanted to bust butt and I got permission to abandon the family for a weekend. I could get the 4*60 framed up in a weekend ready to cover. It really is that quick of a build. Here are some notes that will really assist you in the build.
In the step where it tells you to glue in the pieces in on the bottom of the fuse from the leading edge of the wing to the nose (landing gear plate and 1/8th ply) skip that. Then fit your wing, square it up and then drill your holes for the wing dowel. once that is done go back and put in your gear plate and 1/8 ply.
Doing this really helps in getting this done quickly and accurately. If not it is a pain to get the holes drilled in the wing.
Michael.
