ENGINE PROBLEM!! URGENT!!!!!!
Hey guys, started engine up today, thought i'd iron out some little problems i was having, had it in idle, then all of a sudden, engine starts screaming, thought to myself??? looked at the stick, was fully down, looked at the servo, was in the idle position!! noticed there was barely any smoke, thought shiiit, pulled the fuel tubing out to stop it,
i then said, that leaned out for no reason, took the engine out, clean it up, tightened glow plug etc, then gave it the pressure check, finger over the exhaust port, and over the fuel nipple, blue into it, i could feel air escaping, didnt know where though, so i poured fuel down the carb, did the same procedure, fuel began to drip from the front bearing, thus an air leak
need a new bearing, i just need to confirm the part number so i can order it
is it- OS26731002
need instant reply thanks
