RCU Forums - View Single Post - Control Surface leading edge alignment
Old 07-18-2007 | 05:56 PM
ro347
My Feedback: (13)
Default Control Surface leading edge alignment
I am currently assembling a Hanger 9 Pulse XT 40. After gluing the hinges to the wing and ailerons I notices that one of the ailerons is not flush on one end with the rest of the wing. The aileron's surface sits about 2-3mm below the rest of the wing's bottom surface. Again this is only one end of the aileron that does this. I am assuming the hinge slots were not alignned properly. Is this enough to worry about? Should I use debonder(never used before) to undo the CA and make it flush? Will the debonder affect the wood, covering in anyway? Can I reuse the hinges(probably not)?
Thanks for your time!
