RCU Forums - View Single Post - Need some help/advice removing E-Clipss!?
Old 07-18-2007 | 11:21 PM
csp1971's Avatar
csp1971
Default RE: Need some help/advice removing E-Clipss!?
When I had to replace mine, I put mine in a vice (not horribly tight) and used a very small flathead screwdriver as others mentioned above. To keep the e-clip from flying off, just put a rag over it while you push the e-clip from around the stub.
