RE: CG FOR SEAGULL AT6 TEXAN
Arno
Hi, I'm just about to build one myself (OZ version) and took very close note of your comments. From my experiences with two ARF's of late, "Scanner" " Air Speed 40" the recommended CG is back about an inch (2-2.5cm) of where it should be for (my opinion) of nice flying/landing qualities. Subsequently i was landing long, at Mach 2, in a sweat, and making battery, receiver, engine mounting forwards adjustments very quickly. The Scanner required lead!!
The book says 5-6cm at the wing tip. I can't vouch for your calculations but sounds logical. I will start mine at about 2.5-4cm at the tip and go from thier. Interested in how you go with it.
Luck to you
DLA
