RE: diff lock
I don't think that would be a very good idea to be honest with you. If you lock the rear differential and some how one of your rear wheels locks up(bend a drive shaft or whatever) your going to destroy the entire drive train from the clutch bell back the rear drive axles, stripped spur gear, stripped clutch bell, Bent center axle, possible broken diff, bent wheel axles and so on.
