RE: Landing Gear Newb Question
every airplane is different but yes it is common for the nose gear to be smaller.
when upsizing gear keep the same difference, ie: if your stock nose gear is 1/2" smaller than your mains make sure your upscale wheels have that same 1/2" difference. That way the angle the plane sits at will be the same. Make sure to check the balance because of the added weight.
