RCU Forums - View Single Post - Saito 150 Problem Please help
Old 07-19-2007 | 10:50 AM
jschwenk
Default RE: Saito 150 Problem Please help
I tried opening the valve on the hight speed and low speed and it throws props now. My hight speed is now at 5 turns out and the throttle transitions are good and it also holds a steady idle. I really can't move the take up higher or the engine down. Would a fuel pump solve this problem, if so what kind should i get?
I also tried changing the glow plug and changing fuel lines. I looked over the fuel take it still looks fine.
thanks
