RCU Forums - View Single Post - P Factor and engine offset
Old 07-19-2007 | 02:23 PM
FlooredCOBRA
Default RE: P Factor and engine offset
I would of thought the Harrier would of had built in right thrust already. But to add yes washers work perfectly behind engine mount. to measure use a protractor and you should be good to go. Here is a link to a paper protractor to print out. Works good to tape to plane- http://www.ossmann.com/protractor/co...protractor.pdf
