RE: Saito 150 Problem Please help
Do you use a tac? If so lean it to where the rpm quits increasing, then open the needle until you drop around 250 rpm.
IF this doesn't work you might have trash in the needle/seat area on the carb. You might have to disassemble the carb and clean it.
Also Are your valves set properly?
