RE: P Factor and engine offset
Thank you both VERY MUCH for your help!! I don't know if the Harrier has built in right thrust or not, but i didn't use the kit engine mount. I bought a Du-Bro engine mount and had to drill it out to mount the engine my holes were probably off a slight bit, I had them as close as possible but 2deg is not much to the human eye. So if i was off 2 deg in the wrong direction that would have made the total correction I need about 4 deg, I'll try a washer then check until I get it right. Thanks again.
