4-stroke madforce
When you float a valve, the valve doesn't close because the valve spring can't react fast enough. Since the valve is still open when the lobe has rotated to a point where the valve should be closed, there is play between the push-rod, rocker arm, and the lobe. You can't have one without the other.
