RCU Forums - View Single Post - how to make a wire drive?
Old 07-19-2007 | 05:00 PM
crashbuilder
Default RE: how to make a wire drive?
Wow, many thanks Easy
I've been reading about these things for a couple of days and still didn't understand!
I made a mock-up where the stuffing tube actually bent with the wire. Surprisingly that didn't bind that much .. just about slightly more than my solid shaft.
I see the light.
Now I have to decide if I want to do my bend in the hull or after the transom. If I do it internally my drive angle will be fixed at 0 degrees. If I go external I'll need to strengthen my rudder stand-off to act as a strut bracket.
Do Mono's really need positive strut angle (prop face pointing to the sky)? I'd initially planned on a fixed set up.
Actually an external bend might not be possible on a 15" mono without setting the prop way back .....
Conversley an internal set up might leak a sieve.
