RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 07-19-2007 | 05:38 PM
  #3784
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
Radioflyer,
If your using 1, 2 or 3 heat sinks and your not experiencing any glitches your fine. My reference to more than one heat sink, I was concerned with the lower heat sink being to close to the 3n1 or 4n1 controller and transfering heat to the controller and over heating that. Also, if the heat sinks aren't tight on the motors and slip and slid, it could cause a harmonic frequency and cause glitches.
If they're tight and the controller doesn't seem to be over heated your okay, fine.
OH, I hate Tuna! Yuk!
Dave / Choppersrule
ORIGINAL: theradioflyer
I had two on it and then Choppers said more than one is a hinderence so I went that route for a bit. I now have three on it with the top one modified to fit the top perfectly while not blocking the air holes, I'm going to try something else as soon as I mock it up.
The Tuna fishing trip sounds like a blast!
God Bless!
