RE: ENGINE PROBLEM!! URGENT!!!!!!
Hmm as as i said before, everything else looks very healthy, every thing is as it should be, apart from obviously the front bearing with a little air leak, and the ring, im not actualy sure if the ring broke during use, im sure i would of known if it did. or if i broke it while i was removing it.
as for the pin on the piston, its fine and as it should be
