RCU Forums - View Single Post - Cornering tricks?
Old 07-20-2007 | 08:57 AM
traxxasracer_4
Default RE: Cornering tricks?
hairpin: you should slow down (let off the throttle very little brake) hit the middle APEX of the turn and accelerate out of the turn
"s" turns: carry a constant speed through the turns use the blue groove if there is one if not use the APEX tecnique by hitting the middle of both curves.
hope thisinfo helps if you need anything else with this issue you can PM me with questions.
