RCU Forums - View Single Post - JetLegend F-16 Kit Build
Old 07-20-2007 | 10:37 AM
drdoom
My Feedback: (9)
Default JetLegend F-16 Kit Build
I tell you , That the JetLegend Kit is Nice But it is absolutely without any Instructions. If you aren't Careful, you could end up with a number of problems that would be difficult to overcome. Does anyone know if their is room to set the fuel cells in foam. without deforming the fuse? Should they float in foam or is a good silicone OK?
Any other suggestions or Ideas on the build of this kit including sequence will be very much appreciated.
