g-3
hi i am doing an E conversion on a tf cessna 310 i am using eflite power 60s phoenix 80 amp speed controllers and 4 11.1v 5000mah packs. I was at the LHS and they programmed thge 310 with all my parameters to see how well it will fly. when we went into edit plane the clerk set the cells at 6. The thing preformed bad! well i have 12 cells total 6s on each side so since the simulator cannot distinguish I am using seperate packs I said change cells to 12. Wow what a difference.
my ques is is the programming correct using 12 instead of 6 we also used my exact props and pitch,.
