RCU Forums - View Single Post - 110cc bme for 1/3 laser?
Old 03-11-2003 | 12:13 AM
Desertrat's Avatar
Desertrat
Default 110cc bme for 1/3 laser?
I said I wasnt going to argue. If you're going to quote numbers off a 28" prop, then by golly you oughta explain that your not getting 28" worth of thrust from the prop! I can get 6500 rpm out of the Mejzlik on my BME, but I get better vertical performance out of 5900 rpm and the NX.... my point is you really need to quote <which> prop you are using when you post RPM figures...
that is all.
