RCU Forums - View Single Post - loops in normal mode
Old 07-20-2007 | 09:23 PM
TrumpetRhapsody's Avatar
TrumpetRhapsody
Default RE: loops in normal mode
WARNING!
Just a little tip before you try idle up while flying: With your heli off, switch between your flight modes, and make sure all your trims match. If you are in normal, with trims set, and switch to idle-up with neutral trims, your heli will start drifting and the gyro will not read neutral anymore. This could be disorienting if you're not expecting it.
