Arrow,
Here it is, see post #26. Not sure if this is what you need.. Also, something to keep in mind, on the Cp Pro, when you move the throttle stick full throttle the swashplate moves down. On the HBK2, moving the stick to full throttle, moves the swashplate up. Both in normal mode. It's like that because of head design.
http://www.rcuniverse.com/forum/m_47...tm.htm#4935101
Dave / Choppersrule
ORIGINAL: ArrowNaughtic
Started on the installing the Dx6 on the blinged blade with the CP Pro 3 in 1 but have run into a few issues. Anyone remember seeing some basic programming for the DX6? The DX7 programming is quite different and doesn't seem to help much. All I really need is channel reversing and swash settings. Doing the same with the HBK2 and am in the same boat. I downloaded the HDX300 setup vids last nite of finless's and hopefully I can decipher and transfer the basics off that.
I am just looking for the easy road.........heh
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
