RE: Need some help here
Check by hooking it up to a 4.8v battery and some servos. To check crystals I usually swap them out and compare results. The case may be opened by inserting a slot head screw driver and prying the tabs open. There may be 2 or 4 tabs.
I have dropped a few receivers from brutal plane crashes and had no problems. The most fragile parts were always the servos.
Ryan
