RCU Forums - View Single Post - Northstar mod question
Old 07-21-2007 | 09:58 PM
oxyfx
Default RE: Northstar mod question
Ryanpilot,
How did you make it run with an 11" prop when the clerance over the hull accept only 10" props? I have to repair mine anyway, so if there are modifications to be done, now is the moment. Besides, I followed the construction steps from BalsaUSA to the letter, and applied some of newrc's modifications like the triangles under the nacell. As a result after the nose in the tail and nacelle remained intact only the fuselage broke under the wing...
Newrc, do you have a picture of the groove you made in the hull to accept larger propellers?
Thanx, Ox.
