RCU Forums - View Single Post - Question
Thread: Question
Old 07-21-2007 | 10:02 PM
ezveedub's Avatar
ezveedub
Default RE: Question
Thats the Idle up switch. You use it for 3D or inverted flight. Make sure its down when starting off and only turn on when your throttle stick is in the middle. If you turn it on with the throttle stick down, you will produce a lot of drag from the negative pitch of the blades at full speed while on the ground. I use the idle up for hovering once in the air.
