RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 07-21-2007 | 10:19 PM
  #3796
crashcrash
Default RE: Wheeeeeeee.......... Blade CP!
ORIGINAL: Barrrick
RICK HERE....Hello y'all
Been at the bench all day long, trying to set up the PRO and the CP
Just now, put the CP on the ground, with the new (replacement) stock motor. With plastic flat bottom blades, and the throttle on high with TRIM also on high, the helo lifts itself up from the ground not more than ONE INCH or so. Considering it's in ground effect it seems to be quite stable in all directions, but the LIFT is not there. Blades and paddles show perfect alignement. The body has no shakes or vibrations at all. Everything is smooth as can be. Tail blades were also replaced, even though the originals look to be fine.
the old phartt can use SOME guidance !
from the little knowledge I have acquired reading y'alls adventures : There is here a PITCH problem OR a HEAD SPEED problem ! ( am I on the right track ? )
Hows the battery Rick? sounds like you might have a dead cell or two. Charge 'em up and have someone at the LHS throw a digital meter on it. REALLY sounds like a weak battery at this point.
