ORIGINAL: ArrowNaughtic
Hey ya old PHART! I am voting not enough pitch. have you tried turning each servo link in one half turn and then try to hovor again? Crash could be on to something too, as I have come to know him over the past 8 months he is definately the setup guy! If I had enough patience I would send him all my helis for a setup diagnostic and fine tune! Witha pitch guage if you have one you could verify wether its the pitch or not. Motor unplugged and then fire up Tx then plug in heli after it arms move the throttle to half stick.......pitch should be 0 degrees.
crash and choppers.........I used the CP Pro settings for the dx6 on the HBK2.....worked like a charm! I will post some pics in the other forum and a few here of all the fleet after I get the Blinged CP set up. All i have left is the pitch settings on it and its ready for flight again!
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
Not arguing....anything is possible but....increasing the pitch reduces head speed= crappy stability and performance. Granted, pitch must be right, but headspeed must not be reduced to the point of impairment of the operation of the heli. I'm 99.999% sure it's battery since he changed the motor. BTW...a bad tail motor will cause the same symtom he discribes because it'll pull from the main motor. Rick, if you haven't done so...change the tail motor too. If that don't do it....gotta be battery.
