RE: Diff in Props
What would the end result be in engine rpm ? If you ran a 12x6 and changed to a 11x7 would rpm stay the same ? Have a lt-40 with OS .40 with 10x4 prop running 12700. What prop should I change to to increase rpm's or maximize power. Spec's say the motor should run up to 15,000 rpm.
Thanks in advance.
