RCU Forums - View Single Post - First Gasser
Thread: First Gasser
Old 03-10-2003 | 09:13 PM
wvarn1957's Avatar
wvarn1957
Default First Gasser
The Walbro carb gets it's crankcase pulse through a hole in the carb mount attached to the cylinder. That is, unless the previous owner tapped the diaphragm cover and tapped the crankcase so that a different carb stand-off could be used.
Usually the Walbro carbs that have two connectors have a primer bulb and the connector on the carb body goes to the tank suction line with the outlet on the bottom of the prime bulb to a vent line.
