RCU Forums - View Single Post - HELP! Robinson 22 Problem
Old 07-23-2007 | 04:26 AM
mrasmm
Default RE: HELP! Robinson 22 Problem
you might try checking the motors to see if one is failing, or you might check and make sure that both sets of blades spin freely. If there was some binding it would cause that problem
also you can check out the cx2 guide and see if you can find anything there. It's a pretty simular heli and it is a good resource.
http://www.heli-max.net/mediawiki/index.php/Index:HOWTO
