RCU Forums - View Single Post - Servos problems
Old 07-23-2007 | 08:15 AM
Warbird Joe's Avatar
Warbird Joe
Default RE: Servos problems
ORIGINAL: TopherGreen81
I just got a new radio The Airtronics RD6000 Super and I charged the batterys and hook every thing outside the plane before I installed it and the servo start twitching when I turn on the Tx. I don;t understand what the problem is. Can anyone shed some light on this subject.
Chris
Hello Chris. It sounds like you had the servos hooked up first then turned on the TX. the servos are twitching because they couldn't lock into anything. You should always turn on the TX first then the RX and vice versa when turning them off. RX then the TX. that should fix your problem.
