RCU Forums - View Single Post - AXE CP Bounces Up and Down
Old 07-23-2007 | 09:19 AM
dlfowler
Default AXE CP Bounces Up and Down
Hello,
The other day I replaced blades, servo arm, and tail motor. After replacing the items, I fired up the heli and it ran great on the ground, just a bit of throttle. Then I get up to half throttle and it's still on the ground, then it shoots up about four feet, hobbles around, then "pushes" itself back down to the nice hard concrete, where I broke another skid. So, I did some research, found that I should check the following:
1. servo arms at 90 degrees
2. Pitch Angle
3. Tx settings
My pitch angle is at 2 degrees, I think! I am not sure how to read the doohicky. Items 1 and 3 I believe are good-to-go. Any help is greatly appreciated.
Sincerely,
Derek
