Wet Start
The pics you posted do not look too bad. I do not think you will have any problems. Next time you run out of propane, shut the engine down and spin it with the electric starter to evaporate the raw fuel. wait few mins before next start up. In a very wet start up, a properly programmed ecu should shut down the turbine. You will get the feeling of proper propane amount after a few starts. I hope this helps.
