RE: New CMP Cessna 182 .52 size
Sure can, I'll check on it tonight after work.
The assembly is going pretty well. The only couple of issues i've encountered are the servo trays in the wing when installed, they will show through the other side (top) of the wing. I had to trim them down some. I also had to trim down the opening a bit so the servo would fit. I am using DS821s all around.
It has taken me quite a bit longer because i am installing NAV lights on the wings and vertical stab. I am not using regular LEDs but the new luxeon super bright 1 Watt LEDs. They are so bright you can see them in plain daylight. I'll post some pics tonight.
