RE: reprogramming Align esc.
The beep sounds are actually produced by the motor, it acts as a speaker for the ESC. So if you disconnect the motor you will not be able to program the ESC. Instead, remove the pinion gear, and that way there will not be any danger.
Be safe!
Georges
