RCU Forums - View Single Post - THE NEW APPROACH
Old 07-24-2007 | 06:19 AM
iceaxe
Default RE: THE NEW APPROACH
sorry its been a few days all , have 3 scale projects going at once so have been building like crazy, anyway things are starting to get really exciting from here on in as you can start to see the apache take shape ,the next step is to construct the nose but i will add that next due to a technical hitch with my camera ,so with out any more waiting we move onto the F.A.B or forward avionics bay construction .
Again we find that this part is rather simple ,and quick to complete ,find the required parts , which are the 3 formers for each side , test fit to make sure you have htem in teh correct place and that they a re a good fit , but dont glue at this stage . Whike we are on the subject of glue i want to meantion that james has made it easy for someone not used to building conventional ply \ balsa build up kits by telling you which parts to epoxy and which you can use CA (ZAP) on ,so that the main structural components are boned well, it really doesnt get any easier than that .
ok now locate the fab side from the balsa sheets now make sure you have the correct side , looking from the rear of teh fuse the fab side with teh cutout goes on the right side and the cut out is so that you can have your switches and fast fuel steup in here as james has already taken the hard work out and made a scale like access hatch for you . ok so here is what the left side fab component should look like
and here is the other side (right) side with teh cutout for the scale hatch
,ok so now that we have the correct parts on the side go ahead and glue teh 6 formers in (3 either side ) then starting fromthe rear glue teh fab sides in place , take care from this point on with teh fab front on teh right side as it can be broken off easily , i know cause i did lol, not problems just CA back into place and dont do it again .
