RCU Forums - View Single Post - odd G-26 problem
Old 07-24-2007 | 09:38 AM
mikenlapaz
Default RE: odd G-26 problem
After fueling you might try holding plane vertical and giving a couple of extra choke on rotations to see if you can expel any vaporlocked air in the carb through the venturi jets. Aspect of the carb may be holding the air and it gets displaced slowly in normal flight.
