RCU Forums - View Single Post - deisel conversion
Old 07-24-2007 | 11:38 AM
Flypaper 2
Default RE: deisel conversion
The injector in a truck diesel are timed for injection because as soon as it is sprayed into the cyl., it ignites just from the heat of compression. Comp. ratio is much higher than on a model engine and one of the the reasons they have to be built much heavier. The pressure in the cyl after ign. is much higher also.
