RCU Forums - View Single Post - Trimmed out but doesn't look right?
Old 07-24-2007 | 01:07 PM
opjose's Avatar
opjose
Default RE: Trimmed out but doesn't look right?
If the trailing edge of the stab is slightly down, then the plane is a bit tail heavy still.
You are compensating for this by pushing the nose down with the trims.
You could fly it as is, or you could try adding more weight to the nose and re-trim.
If the variance is not that much, and you like how it flies, leave it as is.
