RCU Forums - View Single Post - axe cp thread
Old 07-24-2007 | 03:06 PM
  #1368
s_mcflurry
Default RE: axe cp thread
ORIGINAL: alienteabagger
ORIGINAL: s_mcflurry
So...any thoughts about my Axe and its gangsta lean?
Thats an easy one. Remember that the tail rotor conteracts the torque from the main rotor. With the push of both these forces the body of the heli leans to one side. This happens with real helis too only it isn't as noticeable since their weight keeps them perfectly straight. It is a perfectly natural thing for the heli to do. You could try turning the tail rotor a tiny bit to redirect the thrust to counter the lean, but it will still be visible. If you look at the rotor disc during hover you wil see that it is sitting level even though the heli is leaning.
Ah, okay. Thanks for the reply. I kinda had a feeling that this was it but I only heard of one other person mentioning so I discounted it. If I were to raise the tail rotor to the level of the rotor disk (hypothetically) the way it is on, say, an Apache or a Cobra, would this correct my Axe's lean?
