RCU Forums - View Single Post - engine cutting off problem
Old 07-24-2007 | 05:08 PM
ehroof
Default RE: engine cutting off problem
ORIGINAL: jcervantes11
yea we talked about my lightning back then. Right now all i need to do is let my lightning to collect dust for a while
until i get paid. But my new Tsunami i have so much fun hehe. Anyways do i need to change the clutch bell and spring'
on this one? Seem like its not eating up my gears. I'm keeping my eyes on it. Whats ur setup on you're tsunami?
I gtg but i'll reset my needle valve,
also what do u mean on "make the low needle (the one next to the throttle arm) flush with the collar around it."
See if a magnet sticks to the clutch bell, if it does then your ok, if not, you should replace it. If the clutch shoes are nylon then your ok with the shoes and spring, if they are aluminum you should change the spring.
On the side where the throttle arm hooks up, below that, you will see a flat head screw with a collar around it, its kind of recessed, that screw should be flush with the colar around it, not sticking in or out.
