RCU Forums - View Single Post - paging the Real Dogman
Old 07-24-2007 | 08:32 PM
  #45
The Real Dogman's Avatar
The Real Dogman
Default RE: paging the Real Dogman
Soil is absolutely right, if your rubber gasket at the header on the block is in any way allowing air into the system and you will be overheating. That gasket needs to be pristine and seated properly!! All it takes is a pin hole air leak to cause the minimal heating you seem to be experiencing..
