RE: Trimmed out but doesn't look right?
Typically when flying aircraft the only time you are fire walled (full throttle) is on takeoff. Once you have climbed to altitude throttle back to cruise setting, after you are at a good cruise 1/2-5/8 power trim for level flight. Now is you add power you climb, reduce power you descend. You use throttle setting, not elevator to climb and descend your elevator is pitch control not the up down control.
