RE: Trimmed out but doesn't look right?
Iron Eagle......"Now as you add power you climb, reduce power you descend. You use throttle setting, not elevator to climb and descend, your elevator is pitch control not the up down control."
This is the first time I've ever heard this, so I just need to back off from full bore and trim her out at cruise speed....well this makes perfect since! I'm guessing that everything is fine then.....all good news and flying tips too.... [&:]
Thanks guys! Glad I asked....
