RE: Trimmed out but doesn't look right?
One of the most important things you will learn in flying is throttle management, this applies both to R/C and full scale.
Once you lean that the left stick is more than an on off switch for the motor, you will get more flying time, extend the life of your engines, and reduce the strain on your airframe.
Now that not to say that blasting around one in awhile is not fun....
