RCU Forums - View Single Post - Substitute for Ether
Old 07-24-2007 | 10:21 PM
  #893
DannyM2Z
Default RE: Substitute for Ether
Hi diesel lovers.
A recurring theme in these threads is the insolubility of castor oil in kerosene. (By castor oil I am referring to my available favourite; "Castrol M". The kerosine is Oz "Diggers" brand ).
Many years ago I had the requirement to mix petrol with castor oil for use in a spark ignition engine, which had the same result as with castor and kerosene. Rapid separation and no mixing.
This problem was solved by the addition of a tiny amount of an additive which resulted in a mixture of petrol and castor oil that ran the sparkie very well. (Arden .199)
Yesterday I was servicing the spark engine and remembered this additive. So as yer do, I then I mixed 10ml of kerosene with 10ml of Castrol M and shook the mix. It separated quickly. As expected.
Then for the moment of truth. I added 200mg of the additive (<1%) and shook the jar. 20 hours later no signs of separation so I think that I'm on the right track.
Oh yeah, the additive [8D]
LECITHIN - Available from my pharmacy in a jar of 64x200mg capsules. It is a soya bean derivative that helps to emulsify fats in the digestive system so I hope that it is non toxic [:'(]
I suspect that the lecithin has emulsified the castor with the kerosene just as it did with petrol.
I have not tried this 'emulsion' in a diesel fuel mixture yet, pressure of work and other activities push this one onto the backburner unfortunately. But then I have gained much pleasure from reading about the experiments of you all so I offer this discovery for the interested with the request that you share your results with this forum.
Regards from down under.
Cu Later * Danny M *
Danny Maslowicz
ps, Motorboy. A friend gave me a few bottles of Gilde Aquavit, after the effect on me I think that it would make a suitable fuel for most engines ;-)
