RCU Forums - View Single Post - Increasing throws?
Old 03-11-2003 | 11:34 PM
David Cutler's Avatar
David Cutler
Default Re: nbcguy..
Originally posted by new2this
Yeah last night I was adjusting them and that thought did cross my mind. This plane flies so simply that I am not worried so much about losing control (The plane nearly lands itself). I am more worried the rudder or elevator ripping off the plane in mid flight. I am going out tommorow and I will see what happens.
... also, more throw doesn't necessarily mean more control surface effect. It might mean the opposite if, for instance, the elevator moves so much that all it does is create more turbulence around the tail.
... also (sorry!) this is unlikely to happen with a trainer, but excessive elevator movement can make the model snap. That is, roll over on its back when move the elevator quickly and you least expect it!
David C.
