RCU Forums - View Single Post - Increasing throws?
Old 04-15-2003 | 03:31 AM
David Cutler's Avatar
David Cutler
Default Increasing throws?
Originally posted by stick&rudder
I am interested in increasing my rudder throw on my World Supersport .40. If I move the clevis closer to the control surface it lengthens the control link.
However, doesn't it then require you to recenter the surface either by trimming or by manually trimming (resetting the linkage on the servo)?
So, aren't you back to square one again?
I just don't see how moving the clevis out will lengthen the throw.
Moving the clevis closer to the hinge line (which is the effect of moving inwards a hole) means that the rudder moves more for a given movement of the pushrod.
It may be true that you have to re-centre the trim, but that doesn't effect the above.
Think of it this way . . moving the clevis, say 2 feet outwards (if there was a hole there!) would obviously reduce the throw of the rudder, it simply describes a larger circle.
David C.
