RE: A couple problems with my first RC- TT-01 w/ MC330R ESC
Heh, I got problem #1 figured out by setting up the ESC. I had to change the throttle settings on the transmitter as well.
Problem #2 is an issue. I hope I didn't confuse you into thinking that the driveshaft is stuck-- no, that's not an issue at all. I'm talking about the actual motor. It's installed into the chassis, but it seems loose. When I push on the motor, it will budge about 1-1.5 mm. When I add throttle, the rotational force from the driveshaft also makes the motor wiggle a little. Basically, it's probably not stable in there. I think the issue is that the bottom of the plastic tub chassis is warped a little from the heat I applied to the heat shrink while the motor was still installed in the chassis.
