3W ENGINES HELP!!!!!
evan . i have to fess up. i used your slot setup in the engine cowel to help with the cooling . i'm kinda worried about you exaust setup. though it looks great, i can't see where you will get a good back presser to help the engine run better . i had the same setup on a ziroi p-40 only all 12 pipes worked . i hated the black spots on the plane ! haha i went for the 50 cc engine on my spit 'cause i didn't feel i needed that much power. after all it's only 1/5 scale . thanks for your input and you have a nice bird there , ron p.s. what spray gun did you use to put down the camo? nice job i have a badger 150 with a med. tip
