RE: gas fuel with glo plug no ignition
I had the adapter made to use a Walbro carb on my ST-3250.
The throat is the same size as the stock Super Tigre carb.
But is a lot smaller than a 32cc carb's throat.
Is this going to be an issue?
The throat is big enough to run the ST on glow fuel it should be big enough to run it on Gas-Glow.
Aero Nut what carb are you using on your Moki 1.8? I was thinking HDB 6B, I have a few of these.
What is the throat size of your adapter?
